Catalyst Control Centre has disappeared?!
12 Mar 2003
USA
Hey,
Tried to access CCC, but is is no longer accessible from the Advanced Display Properties menu! And I've obsessively deleted all the other shortcuts too, so I'm not entirely sure how to get to it now (or why it's gone!).
I have noticed though that CLI.exe is no longer in the windows processes list... any idea what's up with that?
Cheers,
Suman
C:\Program Files\ATI Technologies\ATI.ACE
look for the cli file in that. might work
or go for a reinstall?
Hey,
When I try and run CLI.exe it crashes and displays an error message (the standard "has encountered a problem and needs to close"). I'll try reinstalling now and see what happens!
Cheers,
Suman
have you recently updated your drivers? I found CCC had moved. Now I access it by right cliking on the desktop and its at the top of the list.
If you run a software firewall you need to let CCC access to the local network else it doesn't start up or crashes.
