- 23 Nov 2005
- Kingdom Of Fife
Hi All,
Attempted to install the new Omegas last night on Win 7 64bit. Used AMD un-installer, then DDU to remove the dregs in safe mode!
When I attempt to install the drivers I get a dialog box popping up telling me two kernel drivers, display and HDMI audio, are not digitally signed (Program Compatibility Assistant) it informs me they have to be signed, and it can not continue! WTF? I have never experienced this before, I was also getting a watermark in the bottom RH corner, informing me the OS is in "Test Mode"
The only way to get the new Cats running is to hit F8 on boot up, and select "Disable Driver Signature Enforcement" from the boot menu. This is then good for that particular session.
I have rolled back to the point just before I attempted to install these 14.12 drivers, with System Restore until I figure this out! I thought the 14.12's were WHQL certified?
Any ideas?
Any ideas?
Drivers are generally pretty painless.
