Hi all,
Operating System: Vista Home Premium 64 Bit
Graphics Card: X1900XT
I have just purchased a Hyundai N91W TFT which has a native resolution of 1440x900 @ 60Hz. I am connected using a DVI cable.
For some reason when using the Cats 7.5 when I select the native resolution the monitor goes blank and says "mode not supported". All other resolutions work fine.
Now if I go back to my XP installation with Cats 7.1 then there is no problem it works fine. Also if I delete the Cats 7.5 and use the windows default driver I can also select the native resolution.
So I think the problem is with the 7.5 cats, However I now have a new problem!
I want to try an earlier Cat version to see if the fault disappears in Vista but after I Uninstall the Cat 7.5's (Thru Control Panel and also using drivercleaner) and the reinstall the older cats my Graphics card is no longer detected and they do not work properly!!!
Anyone got any ideas??
