- 4 Nov 2005
You would have thought this, being my 5th upgrade, would be easy. Unfortunately, I have had a total disaster - of really cosmic proprtions. I am very embarrassed
. And am looking for some ideas.
I was looking to upgrade the below to:
Gigabyte GA-P35C-DS3R
E2160
Tuniq Tower 120
Leadtek 8800 GTX
Del 2407-HC
Screw up no 1. Once set up. The PC would fire up and then switch off for a few seconds, and repeat. I thought it could be the PSU, but wanted to try some alternatives, so took out the mobo and fired it up barebones (ram and PSU only). Same result. I then replaced the Tuniq with the stock cooler, and it worked! I then reconnected everyhing, and not only did it stop working, the mobo would just spark up for a micro second, then nothing.
Screw up no 2. I then replaced the Seasonic with a PSU (only 400W) from my other PC. Worried about things firing up, I reverted back to the old graphics card, and disengaged low priority power sources. Same result
. I put the 400W PSU back in the other PC, and now that isn't working. Absolutely no spark whatsoever. Can a mobo blow a PSU???
Screw up no 3. I then decided to go back to my current setup, so at least we have something working. The good news is that the Seasonic is working on the Epox just fine, and I can boot to windows. Well at least I can hear it booting, because the bad news is that there is no connection being made to the monitor. I've swapped monitors, cables and video cards.
At the moment, I am at an almost total loss, and am running out of spare parts
I've done all the usual including:
checked connections
cleared CMOS and taken out battery over night.
I am happy to admit that some component is knackered, but can't figure out which: mobo, PSU, new e1260 chip? The most bemusing is screw up 3.
Any ideas (other than give up building PCs)?
. And am looking for some ideas.I was looking to upgrade the below to:
E2160
Tuniq Tower 120
Leadtek 8800 GTX
Del 2407-HC
. I put the 400W PSU back in the other PC, and now that isn't working. Absolutely no spark whatsoever. Can a mobo blow a PSU???Screw up no 3. I then decided to go back to my current setup, so at least we have something working. The good news is that the Seasonic is working on the Epox just fine, and I can boot to windows. Well at least I can hear it booting, because the bad news is that there is no connection being made to the monitor. I've swapped monitors, cables and video cards.
. I've done all the usual including:
checked connections
