Need a little advise from the people in the know,
Right this is going to be hard work to explain but will try.
As you prob can see i use chilled water to cool the CPU, Its a Fridge type compressor which in turn cools a tank of water(stock CPU will get -9c). Inside the tank of chilled water is a copper pipe through witch i pump my coolant for the CPU.
We all clear so far
Right this is the BIG Q.
A: Do i add the GPU into the CPUs coolant supply?
B: If you choose A do i put it before the CPU or after ?
C: I have the option to pump the water that's in the tank (The water i chill to cool the copper pipe which carries the CPU coolant)
No matter what i pick i think its going to have an adverse effect.
If i use the CPUs coolant that will ether steal cold water from the CPU or warm the water up for the CPU.
If i use the coolant tanks water that will cause the water to warm up in turn causing the CPUs coolant supply to warm..
What do you think you would choose?
We all clear so far
