23 Aug 2006 at 17:34 #1 The Pat The Pat Associate Joined 11 Apr 2006 Posts 1,858 Location London The stick pads for mine have lost there stickiness, will superglue/adhesive glue do the trick or will it cause problems.
23 Aug 2006 at 19:58 #2 Tosk Tosk Associate Joined 1 Jan 2005 Posts 1,302 Location Stoke on Trent i would use velcro tape or strips much better than glue you can buy velcro now days cheap just google it im sure you will find some Last edited: 23 Aug 2006
23 Aug 2006 at 21:51 #3 Deleted member 651465 D Deleted member 651465 Of course glue will work, but it'd be a more permanent fixture then
