Catz 6 problem
18 Jan 2006
Newport
Not really sure if this should go here or in the PC Games section, but I'm sure a kind mod would move it if need be. :)
Anyway, the missus wanted this for Xmas, so I had to waste money on what so far is a pile of crap! :rolleyes:
The game/software installs fine, but when you run it the resolution is totally off meaning half of what should be displayed isn't. There is a setting page within Catz where you can change the resolution, but a combination of not being able to see half the options and the software itself is totally unresponsive.
I've found the text string in a config file that sets the resolution, changed it to what the Windows resolution is, but now what is displayed - although being smaller - is off centre.
Anybody got any ideas what to do with this POS before I try and take it back to the shop?
My kids use the Dogz 6 game. Just checked and it works fine at 1024*768 the native resolution of the screen they use which is a 15" LCD.
