CCC Fan speed thresholds?
Kyo
Kyo
11 Oct 2003
Hi
Not used ATI for a long time and just installed the latest driver with CCC. I would have used Rivatuner but i thought i'd try it out.
If i remember correctly, you can customise the fan speeds in profiles so that they can speed up or slow down on different temp thresholds? Looking at the new CCC i dont see how you can do this to regulate the fan speeds a bit better?
any advice would be great.
Cheers
Kyo
