- 22 Mar 2009
- Cornwall
how safe is it to OC just using CCC settings? do they set the max settings to something well within the saftey limits of the cards?
is there a ratio for gpu:memory clocks or do you just get the gpu to just before it fails stability, then adjust memory until just before it fails stability?
Increasing the GPU clock will give the the biggest gain in performance so I'd start with that and once your've found you maximum stable OC, move onto the memory.
As kristmace has pointed out, the CCC will only give you a little to moderate OC. If you wish to go beyond the GPU clock parameters in the CCC you may have to use a 3rd software like MSI afterburner, RivaTuner or ATI Tool.
thing is, i dont want to kill my new gfx card, so was just going to see how much, if any, gains i would get from using CCC, if it was safe. if that went well and the gains were noticable, then maybe i would consider a high OC, but if i wont actually notice the gains in anything other than benchmarking, then there is no point in risking killing my card.
Lol you won't kill your GPU unless it was running at over 100 degree Celcuis or if you increased the GPU from 775mhz straight 1000mhz and even then, you'd probably get the BSOD or the system would just reboot.
If you overclock safely, then you'll fine - make sure you monitor the temps of your GPU.
I don't think your AMD Athlon II X2 250 @ 3ghz will bottleneck your 6850 so hopefully any increase you make to the GPU clock will increase your performance in games.
Let us know how you get on.![]()
if you look at my 3dmark results in one of my other posts, the cpu does seem to be holding it back a tad, the difference between my old 9800GTX on my old i7 system.
just remembered i have DiRt2 on my steam account (thanks to purchasing my HD5770s in my old pc) it struggled abit in DX11 mode with the 5770s, should the 6850 be better?
has been benchmarked and was not that impressed with the score, barely beat my 9800GTX and HD5770 (albeit they were in an i7 machine)
The i7 is faster clock for clock compared to Phenom CPUs so that would most likely explain why the 9800GTX and HD5770 are both able to achieve decent framerates but the 6850 should still be higher.
However, the 9800GTX is only a DX10 card so will mostly run in either DX9 or DX10, which will give you higher framerates than running in DX11.
Are you comparing like for like i.e. the setting in the game are the same?
What framerates are you getting from your 6850 compared to the 9800GTX and HD5770?
Try running Dirt 2 in DX10 as that should give you a nice boost in FPS.
im not sure, as it was last summer when i had my i7 build, so cant remember what the settings were.
The thing that you have to remember is that if you maxed out the video settings on Dirt 2 when you owned those previous cards, then the graphics would be pretty much identical between the three cards. The only improvement you'll notice in an increase in fps.
i couldnt run dirt2 with everything maxed as it got proper jumpy, i struggled to find any game that would max the settings, but i was playing at 1920x1080. even fifa10, which i dont think is that gfx intense didnt like that sort of res with settings on high.
Hmm, something doesn't quite add up if you are not able to max 90% of the games out at the moment.
On my bedroom gaming rig, my ATI 4850 along with an Intel dual-core E6300 @3.2ghz, can max out 90% of the games that I play @1080p (no AA though) and on Dirt 2 maxed out, I get around 35 - 40fps with no judder, stutters or jumpy gameplay at all and I'm using Catalyst 10.9 if that helps.
Both your CPU & GPU are noticably more powerful than my bedroom rig so you should be getting at least 50fps, which shouldn't cause any jumpy gameplay at all.
I would seriously look at overclocking your CPU a bit and see if that makes a difference because theres a good chance that it is holding back your 6850, especially if you are overclocking it.
Btw, what FPS are you getting for Dirt 2?
DX10 for you and DX11 for the OP. Not comparable.
