CCC question
30 Nov 2007
This may be a daft question but.....
If i use CCC to force stuff like aptive anti alasing, but then close CCC and disable it from running, will the settings still be forced ?
reason i disable i is because CCC and Afterburner cuse slight lag issues, and was only by sheer chance that i discovered it was caused my both apps running together.
Afterburner is running my fan profiles so im not wanting to disable that
