- 18 Oct 2008
- UK
hi,
im wondering if possible a dual ccfl kit can be made to work without the rocker switch?
i want to wire up 3 sets of ccfl (so thats 3 invertors using 3 rocker switches)
to my fan/ccfl controller installed on my front bay (lamptron hummer 100w per switch) and the controller only uses molex connector to turn on/off device which the ccfl kits have but its the rocker switches i want to get rid of so is there a way so the controller can turn them off/on via its switch through molex?
thanks..
HRhino"
thanks..
HRhino"
