- 17 Oct 2002
- West Midlands
Afternoon, i have just started to get my teeth into Cisco as ive completed my relevant MS certifications, as such ive recently bougth a Cisco 4000M router Running 12.1 IP Plus and Security IOS.
It has the following interfaces:
2 x RJ45 Ethernet Interfaces (2 x 10baseT + 2 x AUI)
4 x DB60 Serial Interfaces
4 x ISDN BRI Interfaces
At present im only interested in the ethernet 10BaseT portion of the router as i want to get to grips with console commands and basic routing between two lans.
To start i ran through the System setup menu, assigned the router a hostname, created an "Enable secret" password and a logon password for terminal access and via virtual connection.
I have assigned ethernet0 and addess and mask of 192.168.1.0/24 and ethernet1 an address and mask of 192.168.255.0/24.
I have also enabled IGRP with an ID of 1.
Now i have setup two routes as follows.
192.168.1.0 255.255.255.0 192.168.255.0
192.168.255.0 255.255.255.0 192.168.1.0
This allows me to ping each interface once hooked upto two seperate switches via cross-over cables.
What i would like to achieve is to have all pcs/server on the 192.168.1.0/24 network and infrastructure devices such as my firewall on the 192.168.255.2 network.
The only problem is for far is that i cannot make a connection to the internet from the 192.168.1.0/24 network.
For the record i have also specified a default-gateway under the menu:
Router>enable>Config term>
Could anyone be of assistance how i might go about enabling internet access from the 192.168.1.0/24 network through a firewall on the 192.168.255.0/24 network.
Help would be most appreciated.
Run before walk and all that.
