Hopefully someone can advise on sending HMDI signal via an ethernet switch.
Current setup is as follow:
House is networked with most rooms having 2xCAT6 plates that go into the loft where there is a Netgear JGS524 24 port switch
Broadband Router can plug into any room port or the switch to provide internet connectivity throughout.
What I'd like to do:
Setup our CCTV system and split the HDMI signal from the NVR to allow viewing to 4 different room TVs using the Netgear switch we have.
Is there a way to get the CCTV NVR output signal into the Netgear switch, then use the switch to send the signal via any room ethernet plates?
Online on Aliexpress I saw this which basically shows a diagram of what I want to do:
https://www.aliexpress.com/item/32828656490.html
Not sure what exactly I should be buying as can't see something similar on Amazon for example...
Would the above setup like from Aliexpress even work?
Could anyone direct me to some hardware that might work?
Thanks!
Thanks!
