- 27 Aug 2019
Hi,
I'm looking to set up a basic CCTV system.
Ideally I would like to have 2 IP Cameras (maximum of 4 total in future) to start with which connect to my network and record directly to my PCs hard disk. Is this possible?
In terms of the cameras I was thinking I would like something that is:
- PoE
- 2.8mm Lens
- 2MP+ Resolution
- IP Rated
I found these:
- HiLook by Hikvision IPC-D140-H-M for around £65
- HikVision 4MP DS-2CD2145FWD-I for around £101
Does this sound reasonable or is there any thing else you would recommend?
Thank you
- PoE
- 2.8mm Lens
- 2MP+ Resolution
- IP Rated
I found these:
Thank you
