cd drive cover-up
6 Feb 2007
North West England
Hi
I am going to be gettting the Lian-Li PC-7 case and using my old dvd drive which is black (and yeah PC-7 in black is out of stock) will i have to buy a bezel if i want it to match ?
Thanks
search on google for a stealth harddrive mod and see if you like the idea.
What you basically do is remove the plastic cover from the drive then stick one of the cases bezel covers onto the drive draw with velcro of something similar making sure the bezel is inlign with the others on the case. have a look on google and you might understand what i mean. you might not even like the idea once you have seen a few pictures!!
If you need any help ill try post some pictures for you.
Hamoodii said:
stealth it ;)
go to the case central section on theres a thread on a-z modding :)
as he said stealth it will be allot cheaper and will look allot better dont use my original post for instructions go to the site above and see how to do it.
