CD Drive Problem
6 Mar 2009
Have 2 CD Drives installed, one has jus died so put in a new one! But when i put the new one in windows xp doesnt reconise any of them. But when i put the new one in on its own windows finds it alrite! Wat is the problem???
Both are connected by IDE
What are the master/slave positions of the two drives when they are both in? If one is faulty is could be causing an entire IDE problem that the other can't bypass.
The jumpers are the little plastic bits covering 2 pins. Carefully pull them out and place them on the relevant pins (see above diagram link).
Put the one at the end of the cable as master the other slave.
Do you have one or two ide conenctors on your motherboard?
