Hi folks
I could do with a little advice please.
I've been putting this task off for ages now.
I have well over a thousand CD's that I'm wanting to rip on to a hard drives. All legit and for my own use and not for file sharing I may add.
Can any of you recommend some software that I can use that will rip the CD's at the highest bit rate possible and can also capture all the Album cover artwork? Also is MP3 still the most future proof format to use or is there something better??
It doesn't have to be Freeware I don't mind paying for something that works well.
. EAC ensures your rips are bit for bit perfect and FLAC preserves the exact same quality with less storage requirements. What you don't want to do is rip to a lossy codec only to need/want to use another lossy format or lossless.
