CDFS - format?
Xee
Xee
13 Jun 2003
In front of PC
CDFS - format USB stick?
I have a USB stick with a CDFS file system on it, with some presentation files.
I would like to be able to format it to FAT NTFS, etc, so that I could use the USB stick as normal. As at the moment I can not delete the files on there.
Any ideas? :confused:
Sorted - Went to device manager, disabled it, then i was able to format it. :)
Could some kind sole, download the U3 remover from this website (http://www.u3.com/uninstall/final.aspx) and upload it somewhere as a .txt file so I can download it at work.
As this U3 app provides a free downloadable utility to remove the CDFS partition and files from flash drives.
