Ceiiling speakers
22 Mar 2014
Plymouth
Hi guys I finally renovated my living room after 1 months i want to install ceiling speakers as the space is limited x4 in each corner of the room. Room 4.5m by 5m. With tv and siting position in the one corner. What sort of speakers would i need ? I currently got Dali Epicon 2 in my music room and looking for 70% of the sound quality . Also what sound compromise would I be making for having speakers in each corner of the room and sub vs regular stereo with sub. Unfortunately I don't have enough depth to put in walls Many thanks
What exact use are the ceiling speakers? Atmos or just general sound and use as LR, for AV --LR & surround LR or four speakers used as all channel stereo?
Options are bolting speakers to the ceiling (joists) or actual in-ceiling speakers, or just mounting speakers on the walls as high as possible, Dali Alteco C-1, or for high end, these
Dali do make in ceiling speakers (about £300 each) Phantom E80's.
I've just ordered the Phanton E60's for my place. Although too far away from install to comment on them.
@SamyBoy13 Unsure if it's an option, but i've also gone with these. You mention not being able to use In-Wall fronts, but maybe an option?
I fitted Polk Audio RC60i's back in 2019 and have been pretty good since, directable tweeters help imho, yamaha centre hidden behind the LG GX tv and also hid a sub underneath the tv for a bit of bass, driven from an Onkyo TX-NR686 for a 5.1 setup and has worked well for Virgin TV, Streaming and local NAS files.
Have you thought about mounting Opticon LCRs on the wall? Ceiling is ok but you cant get away from the fact its directional unless its just light background music you are after. I have two Dali E60s in the roof for Atmos with my home cinema. They're sound great and fill a the room but I have LCRs on the rear and floor standers at the front.
Yeah it's either background music like in meeting rooms, or in dedicated atmos system. I really wouldn't want to have ceiling speakers for "proper stereo" listening.
I use some bookshelf speakers as high as possible in 9.3.4 system as atmos heights, two pairs. Although because they have a wider bass response than small discreet ceiling or atmos, and they're aimed at the listening position, they can operate as stereo speakers
