Would it be an easy job to replace a ceiling extractor fan for a novice?
The current fan is 15 months old and will hopefully find a like for like Vent-Axia fan. So would I be right in assuming with the unit being the same size, screws etc will more than likely be the same?
Or should I just call the professionals in
Thanks
Thanks
