Electrical thread incoming. Can someone check this for me please
Will be installing a Hunter Industrie II ceiling fan tomorrow. I wont be needing a switch for it as we bought the remote control so its a simple case of running a cable from a known junction box on the lighting ring and breaking it over a double pole fused spur. My questions are this;
A. Fused spur rating?. The fan is 80W, there's no light fittings to it, so 80W/230v = 0.35A so I'm thinking a single 3A double poled fused spur will be fine, am I correct ?
B. Wire size, existing lighting ring is IIRC (I will check) 1.5mm which is good for 13A.
Have I not considered anything else ?
.Will be installing a Hunter Industrie II ceiling fan tomorrow. I wont be needing a switch for it as we bought the remote control so its a simple case of running a cable from a known junction box on the lighting ring and breaking it over a double pole fused spur. My questions are this;
