Celeron or P4
Permabanned
31 Jan 2006
I have bought an LGA 775 motherboard. It will take either the Celeron upto 3 gig or a P4 upto 3.4 gig. Sis 964 chipset. Is it worth buying the Celeron 2.66 as I hear you can run it at an FSB of 800 and it'll do 4 gig? would that be any good for gaming? I was going to run it with a 7600GT and 1 gig ram.
dont get the celeron, they're not designed for gaming at all... get the P4 :)
Celeron's are cheap for a reason, they're budget CPUs ;)
I was given a 3.2Ghz Celeron the other week.
Had a play, then gave it to my mum to replace her Duron 1600 system.
2 days later she brought her PC back and asked me to put it right for her with her old stuff.
Enough said.
Looking at it, a P4 is a sports car, but a Celeron is a Lada... They may have the same engine cc's but obviously a tuned engine is a lot quicker than a cronk like a Lada
contrary to popular belief the newest celerons at least arn't that bad.
I built my mum a basic system based around a Celeron D336 (2.8ghz , 256k L2 cache, 64 bit extensions)
It is quite nippy doing normal every day applications (sage, word, etc).
It is also faster loading apps that the Sempron 2800+ (Thoroughbred B 2.0ghz, 256K L2 cache) system I built for next door.
Overall not a bad chip for the money. Not that good for games but will still work well enough.
However for the price you can get that Pentium 4 D 805 dual core for just a bit more which would be much better.
We have a Celeron in our lounge computer, and I have to say its awful. For games I got so fed up with it. Thankfully I've worked in a deal to build someone else a computer and get the P4 they are replacing to go in it.
Only compatible with Intel based 955X series mainboards
The motherboard is built on a SIS 946 chipset..
Are you using the same model HardDisk?
Also remember that the Sempron is no speed monster either... Thats also designed as a budget CPU
I know its designed as a budget chip I was merely stating that the Celeron in my mums pc is definately faster overall than the sempron. Both HD's are Hitachi 80gb's.
There isn't a huge amount in it mind you. Might just be because it one of the newer celerons with the 533 bus. The older ones were naff.
