Marketing ploy anyone.Flanno said:Also from readimg the early Cellfactor reviews there are even levels that are so physx dependent they won't run without a physx card, presumably because the cpu is slow or maybe because the developer wished to showcase the abilities of physx in these levels. .
drunkenmaster said:to be fair, and maybe it will be a good comparison, i've downloaded it but yet to install it. my current view is they are useless, the effects they can do aren't realitive or needed in gameplay, merely enhance a couple graphical effects. i'm solely, right now, on the side of, prettier dress on some chick that can look damaged more realistically, or better water effect will not affect gameplay at all.
i could be wrong, i'll smack it on, run with and without the effects, even if it is at 5fps you should be able to see them and see if they make a single bit of difference to you.
but, and this is a big question, the physx chip isn't massively fast, or with a huge transistor count so how much can it really do. maybe it does a couple of effects in such a way that it only works well on their hardware, but could be programmed to work well on a different kind of architechture? i don't know the answer simply.
Greenboi said:Ugh.
I just dont see why a select few cant be happy with free havok instead of £120 ageia minor differences? (im talking in terms of cost..)
carlazai said:Come on thats a very stupid comment when you look at your sig!!!!
Why arnt you happy with the previous gfx/cpu/ram/onboard sound etc.
Pottsey said:“the physx chip isn't massively fast,”
It’s only about 50x faster then a single core at physics.
Pottsey said:...etc
