- 19 Jan 2006
After years of renting I finally bought my first flat in late August – hurrah!
First job is to rip out an aging, cheap and awful ensuite bathroom and replace it – I’ve gone from an 800x800 shower which was mounted on a riser kit (over 6 inches off the ground!) to an 1100x900 40mm off the ground, with the waste running through the floor. The riser kit was hiding that the floor is out by quite a bit – about 20mm in height over a run of 1200m. I’ve used packers and a good mortar bed to mount the tray level, and the built in run off in the tray is directing waste water perfectly fine.
However, I want to lay the floor now but I need to level it. Would using cement tile backer board be advisable to take out the majority of the slope? I planned to use a 20mm board for roughly 400mm, a 12mm board for roughly 400mm and then to pour self leveller over the lot – is this feasible / advisable, or would I be better off doing similar but with plywood in different increments?
