CentOS Laptop
1 Aug 2003
I'm trying to practice my RHEL (apparently they hate the use of this acronym) so want to have CentOS on a laptop.
I have a Dell Latitude with eSATA and was thinking of trying to boot off an external drive so could have a plug-in CentOS as and when I like but am unsure as to how well CentOS will deal with the laptop's hardware - how good are their driver sets?
I dont know much about centOS I only use it on my Uni workstation but if centOS has a liveCD just boot off of that to see if the hardware works, if the liveCD has major issues then that might give you a little hint of the trouble ahead. Alternatively you have quite well known laptop so maybe just ask in a centOS forum or google and I'm someone else will reply giving you some guidance :-)
I'd never put CentOS on a laptop (modern one), as the hardware support simply won't be much good out of the box (typically).
You'd be better off keeping Windows on the laptop and running CentOS in a virtual machine.
Fedora would be worth a go, I like its combination of similarity to CentOS/RHEL and more frequent updates - good for a workstation or desktop.
I'm running it on an eSATA drive so will only have it on there to play. I've gotten hold of a wireless card that will work and the rest will have to do.
Thanks for all the advice and recommendations.
