CentOS won't boot since powercut/surge..
18 Oct 2002
Around
Lo all,
I run a home CentOS 5.1 server purely for email with Qmailtoaster.
Seem to have had a powercut/surge last night and now it won't boot.
Errors upon booting are:
No suspend signatures on swap, not resuming.
UFS: Can't find ext3 filesystem on dev dm-0.
mount: error mounting /dev/root on /sysroot as ext3: Invalid arguement
Kernel Panic - not syncing: Attempted to kill init!
Anybody have any ideas how to fix this? Tried rescue mode on CentOS install disk but it can't find any Linux partitions :o
Don't really want to have to wipe and reinstall :(
Your RAID array is toasted somehow.
Does it even show up in the controller BIOS, because Linux isn't seeing it full-stop?
Cheers
-Leezer-
Hope you have good backups!
Can you try booting to a prompt via live cd or similar, and run fsck on the ext3 partitions? Should report any file system errors.
With the references to the dmraid driver & the fact that it's a server, I'd assumed there was probably a RAID array in there somewhere.
The number one problem is that it isn't recognising the root filesystem-
Code:
The underlying disk is probably either going to be missing entirely or have had the partition structure damaged by the surge.
First boot from any LiveCD- If the root drive is present, post the partitions list from the command:
Code:
sudo sfdisk -l
If the LiveCD can find & recognise your root partition, things may be recoverable, all depends on precisely what was toasted.
Cheers
-Leezer-
Cheers for the help.
Tried all that and it hda2 just seems to be completely goosed.
Just wiped it and am reinstalling now...only lost a few days worth of mail so not too bad :cool:
I had a similar problem when i used data writeback.
File system screwed and i lost everything. Now only used full journal
