Certificate Message in Opera. Do I need to do anything?
12 Sep 2003
Newcastle, UK
This popped up for the first time today when I went to login to my internet banking...
I don't know if it's too important, should I just click "install"?
The 2Wire part sounds like something to do with my Router as I've only just set it up and it's a BT 2700HGV (2Wire). I'm just confused as to why this Router would cause this message in Opera, when I've had two other one's previously (a Netgear and Billion) and no mesage appeared. :confused:
Thanks for any help and clarification.
It's probably the router's web interface is SSL secured and you don't have it's root CA installed in Opera. If you trust it and can verify that that DNS name resolves to your router's web interface just install it tbh
