CF 290X high temps after drivers
10 Nov 2006
Lincolnshire
I've noticed the temps of my CF290X setup have gone up 25% since the latest Beta driver, using the official driver I never saw 80c in BF4, now at stock the temps are silly in all games that are GPU dependent. How can drivers increase temps? Sniper 3 and BF4 see constant 94c.
Am not sure how drivers can increase temps that much. But what is your case like? How much space they apart?
Am using 14.6 but only played csgo so far, my temps always in 70s on both cards.
Case isn't the issue, the temps are near enough the same with all the panels off. The crossfire setup has a PCI gap between each card
Thats how I used to have mine and my top card would hit 94c all the time. The reason for this is it was feeding all the hot air from bottom card.
Is your bottom card same? 94c or just the top? Am not sure how a driver change can do this though. Because I have been in same situation.
Here what I had to do.
Am sure people getting sick seeing this now :p
What happens if you let the drivers control the fan speed (set to auto (non user controlled) in MSI Afterburner)?
Just tired it, no difference
I can't do that due to the lay out of my case and motherboard MZXT H440. Bottom card gets up to 87c, not as hot.
Long shot, but maybe the drivers have allowed better scaling, better GPU usage, thus increasing the temps??
Probably a millions miles off but you never know..
Either that or the weather perhaps.
Did you have vsync set as on for your old driver options? If v sync has now been turned off, gpu usage will go up accounting for the rise in temps.
14.6 drivers do increase a single Msi gaming's temps by atleast 5-6c.
If the gpu is working harder with these drivers causing the higher temps it's not worth it as the framerate increase is minimal.
Scrap that, just done a hour of BF4 check the temps and their sat at 94 again.
What's making them so hot, never had this before till now.
Edit: WTF just checked fans aren't going round on bottom GPU!! - They start up with boot, which as far as I checked until now, then they stop 30 seconds later.
I think if it's not in use the second card gets shut off. Fire up a game or something like a benchmark and it should come back to life. I think it's called zero core or something.
Yeah as above if you don't have ulps disabled, then bottom card will switch off.
As I said before am surprised that you had temps like that before driver change. The 290's non reference coolers put all the hot air into the case, because your GPUs are so close to each other the top card is getting all the hot air.
You can test, take bottom card out and see what the temperature is like I bet you it will be much cooler.
I had this and iit's reason for mine being so far apart.
This isn't just msi either it's all aftermarket 290s
