CH IV formula Extreme and 1100T ram help
19 Jan 2011
Hi all,
i need some advice with regards to ram for the above Mobo and CPU, i have read really good reviews on the G Skill Flare 8GB (2 x 4gb) sets F3-16000CL8D-8GBFLS however the seem pricey and cant find anywhere with them in stock.
Can any one recommend anything similar or better for OC'ing an 1100T with
again any help greatly apreciated.
Cheers
You don't need anything particularly special overclocking with an unlocked multiplyer, im using 1333mhz value stuff, you want something with better timings over raw mhz
