Chaffinch on feeder
1 Apr 2003
Northamptonshire
My first go at garden birdies. Taken with 120-300 2.8 with 1.4 TC.
1/320, f4, iso 640
Hope you like. :)
Much better !!
Remove the noise from the background and it'll be a decent photo.
The sharpness is good considering the lens is wide open with the convertor and the shutter speed less the focal length.
Much better !!
Cheers, will probably try that.
Yeah, the lens isnt bad. Still too short even with TC for this kind of work. This shot is a fairly heavy crop.
I did use a monopod too. :)
Too short - pffft !!! :)
I've done a few birds shots without the TC and it was long enough for me .
Which monopod are you using?
Garden birds are pretty small! I was only a few metres away from these guys.
Giottos P-Pod - model MM5570, is what I am using. Its a little heavy, but very sturdy. I had a problem once when the tripod bolt became unscrewed from the built-in QR plate. The lens promptly fell off the monopod, damaging both the lens hood (bent) and the tripod foot (half a screw thread gone). Other than that, its great!
I have found it's possible to crop images a lot and still keep sharpness and quality.
I've also been looking at Giottos monopods :)
What aboutrotating the image slightly Joe to get the stand the bird is on perfectly horizontal? Just a thought, but apart from that very nice - particularly like the blowout background.
Cheers Tom. I had already rotated it quite a bit, but I agree a little more would help!
Hi Joe, had play - I hope you don't mind. Cloned the image into two layers, applied a Gaussian Blur to the top layer and then used a soft brush to erase over the bird and the feeder and pushed up the saturation and contrast a bit. Then cropped.
It's a great photo - living in the middle of the city I don't get anything but randy pigeons on my window sill - lucky me :D
