Chair with adjustable/removeable armrests?
8 Feb 2004
In the wetlands...
Hi all,
I am after a new chair, my current one is a fairly black standard office chair - it has lasted a good couple of years but the cushioning has long since failed, and the squeaking is reaching a level where perhaps I should put it out of it's misery.
My main requirement is around armrests; I either want a chair with no armrests, or one that allows you to move them entirely out of the way - this is so I can play guitar in the chair without hitting the neck on helpfully placed armrests.
Any recommendations from personal experience? Happy to spend up to £200 if the chair was able to last for a reasonable duration of time.
Thanks
I'd probably recommend the Nitro Concepts S300 or the noblechairs EPIC Series. They have fully adjustable arms but also they are removable too. :)
