Change brake pads
3 Jan 2005
Bridgend
Looking at changing my brake pads, never done anything like it before but have my trusty haynes manual to hand
its a 2006 er-6f
Can anyone recommend so makes to look out for, don't want to get so cheap and nasty ones, as its my daily commuter
This is from EBC direct
RRP Price
(Ex VAT)
1 FA229HH 2 £23.76
EBC Double-H Sintered Pads for Fast Road Use
2 FA192HH 2 £19.98
3 FA231HH 2 £23.76
Cart Total:
£72.90
Seems a good price just need to double check all the parts
Seems good mate, if you have a local Hein Gericke see what kind of prices they are charging as well as they may carry the EBC pads in stock.
goldfren hh sintered pads
way cheaper than ripoff ebc and tbh I can tell no difference,they stop my zx10r just fine
roughly £36 complete set front n back from busters
and that's coming from a longtime ebc hh user
I'm on sintered EBC. I generally stop at the same rate or faster than the vehicle in front. That is my review.
