Hi Everyone
I have a Playstation 2 which I can only connect to my tv via a component output. The problem is the PS2 defaults to composite output so I get no signal on my TV by default. Normally I know I would have to connect it to a TV using a composite connection, change the settings, and then reconnect using the component tables. However in the absense of another TV, is there any other way to change the output signal type to component?
Really hoping someone will have a magic fix for me, don't really want to have to find another TV to use just for this.
Thanks in advance!
Thanks in advance!
