I just finished modifying and installing a remote controlled lighting system for my Fractal Designs Midi R2 case. I think its a bit different to be able to change the color with a remote. The flashing mode is annoying but I really like the blend mode. Is it just me that thinks this is cool ? It takes a bit of soldering, and modifying. The basic kits you get won't remember the last color if you switch the computer off (which gets really annoying after a while!) - but I sorted that
Also the power input needs to be soldered to a molnex connector. Also you need thermal tape, as the standard adhesive softens with the heat in the computer - and it drops off. I may sell some kits on ebay (totally plug and play with molnex connector wiring / thermal tape etc.) for £20 inc remote - totally plug and play. What do people think, thumbs up or down ?
http://www.youtube.com/watch?v=zF5hEM4Csek&feature=c4-overview&list=UUQ4owhrrdRWGkaq0pOSJhXA
