- 24 Aug 2007
Hi,
I have a HAFX with a 240mm radiator mounted at the top of the case
I had 2 x Corsair 120mm fans mounted underneath the radiator pushing up, and two Scythe Gentle Typhoon 1800s on the top pulling up
After reading some comments from rjkoneil about push pull and airflow i removed the two lower fans, and changed the top fans to push air down into the case
My temps using Prime 95 blend dropped from peaking at 83 degrees to now peaking at 69
Pretty incredible difference, that i really wasn't expecting
