I've got a bit of a strange problem.
My current rig contains the following hardware;
AsRock X370 Taichi
AMD R5 1600X
16 Gb DDR4
3 x SSDs
1 x HDD
Zotac Amp Extreme 980Ti
4 x Phanteks SP140 fans (Chasis fans)
1 x 120mm Noctua fan (on NH-D14)
1 x 140mm Noctua fan (on NH-D14)
All the fans are connected to a Phanteks fan controller, which connects to CPU_1 fan header on the mobo
Existing PSU is an 80 plus silver rated XFX 850W XXX edition
I recently purchased a Superflower Leadex 750W Platinum PSU to replace the XFX as I was getting some coil whine from my 980Ti
Anyway, I swapped the PSU over, and now all the fans are spinning at full speed. I've been into the BIOS and reset everything, reset the CMOS, configured the fan curve in the BIOS as they were before, but nothing stops them spinning at 100%.
So I put my old XFX PSU back in and it all goes back to normal, the fan curve in the BIOS works as it should, i.e. under low CPU temps the fans spin down to about 30%
Could the new PSU be faulty? Or am I missing something obvious?
Thanks!
AsRock X370 Taichi
AMD R5 1600X
16 Gb DDR4
3 x SSDs
1 x HDD
Thanks!
