Changing a tap cartridge/valve help.
18 Feb 2007
London
Hi
Im just wondering should I put any lubricant on a new tap valve/cartridge? Cold water tap in bathroom is starting to leak a little and I can tell the cartridge or washer needs replacing, I know how to change it but not needed to do it a while.
Thanks
Hi
Thanks
You can apply some food safe lubricant to the thread. Not used to stop leaks more to ease removal.
No, no ned for anything. Just pop it in and you're good to go. Make sure to give the tap a proper clean when doing it, scale is what kills these things.
I've had cartidges really stuck, not due to previous over tightening but due to corrosion, if some food safe grease aids in removal, well worth it. Almost busted tap/knuckles removing one cartridge, the other one was fine.
Grease often contains chemicals that will eat the rubber o-rings. I've changed thousands of cartridges in my life, mixer taps, showers, you name it. I've had maybe three which had to be destroyed to get out, but then the tap was so old and knackered that I replaced them too.
depends what grease you use?
"Silicone grease is generally considered safe and suitable for lubricating O-rings. It is non-toxic, waterproof, and resistant to high and low temperatures, making it a versatile choice for various applications. Avoid using petroleum-based lubricants like Vaseline, as they can degrade and damage O-rings"
