Changing an iFrame from an iFrame?
Have a look at this and try something like this:
Code:
<UL>
<LI><A HREF="BeaverHabitat.html" TARGET="BeaverFacts">Habitats</A>
<LI><A HREF="BeaverEat.html" TARGET="BeaverFacts">Food</A>
<LI><A HREF="BabyBeavers.html" TARGET="BeaverFacts">Baby Beavers</A>
</UL>
<IFRAME
    SRC="BeaverHabitat.html"
    NAME="BeaverFacts"
    WIDTH=300 HEIGHT=200>
</IFRAME>
Yea, that's the code to change and iFrame from a normal page.
The problem with putting that code in another iFrame to change the iFrame is that the name="" isn't actually defined on that particular page meaning it cannot change it :(
Thanks,
Craig.
Wouldn't this be classed as cross site scripting? I assume it's not possible for security reasons. Each iframe is a session in it's own right isn't it?
Not sure, I think this can probably be done using javascript on the page that's holding both the iFrames??
Anyway, I've adjusted the page so it doesn't need to use 2 iFrames anymore :)
Thanks for the help,
Craig.
