Hey all
I've currently got all my gear inside of a Antec 902 case. As much as I like it I've gone off the blue LED fans.
I want to change the fans (all of the 120mm ones), but what would you guys recommend? I know I'll lose the ability to control the fans using the knobs on the front of the case and the slide at the back (unless anyone can suggest a fix?...think I saw a youtube vid). The only things the fans must have is NO LED LIGHTS, be quiet, and shift a lot of air......any ideas?
I'm gonna be getting a FT02B-W case before long and putting my rig inside, and slowly moving parts I replace back into the Antec...still trying to think of what to do with it. No lights and quietness is essential.
Thanks guys and dolls
