- 24 Jun 2009
Thismight be discussed elsewhere - i did try a quick search but im needing an answer quick (kwant to insert cpu etc and let the thermal set over night..prob not needed to do but hey ho...)
Basically swapping my CPU from dual core to quad core. To do this ive had to flash my mobo (AM2+ to AM3).
Now can i just switch off..change cpu and power up and its all automatically. or anyway i can help the process (reset bios?) and if i reset it will it keep the new bios settings i just flashed it with.
Hope this makes sense and someone can help quick!
