6 Mar 2007 at 14:55 #1 Gimpymoo Gimpymoo Soldato Joined 31 May 2005 Posts 15,654 Location Nottingham When I click Search, it allways defaults to "Indexed Locations" - How do I change this?
6 Mar 2007 at 14:56 #2 WotDa WotDa Soldato Joined 6 Jun 2006 Posts 6,012 Location Kent Right click on the start menu > properties > customize > search
6 Mar 2007 at 14:58 #3 Gimpymoo Gimpymoo Soldato OP Joined 31 May 2005 Posts 15,654 Location Nottingham Sorry, not to be rude, but ?
6 Mar 2007 at 15:01 #4 WotDa WotDa Soldato Joined 6 Jun 2006 Posts 6,012 Location Kent Elaborate if you're going to do that then..
6 Mar 2007 at 15:03 #5 Gimpymoo Gimpymoo Soldato OP Joined 31 May 2005 Posts 15,654 Location Nottingham My appologies, I was in classic view, did not have those options. I currently have it set to search users files, yet it still defaults to indexed locations Same for anyone else?
6 Mar 2007 at 15:08 #6 WotDa WotDa Soldato Joined 6 Jun 2006 Posts 6,012 Location Kent No, click Edit: Although changing it to indexed files doesn't find that file either. :/
6 Mar 2007 at 15:10 #7 Gimpymoo Gimpymoo Soldato OP Joined 31 May 2005 Posts 15,654 Location Nottingham I dont have that in Classic View. If you click the search button on the start menu, does it default to the Indexed locations?
6 Mar 2007 at 15:18 #8 WotDa WotDa Soldato Joined 6 Jun 2006 Posts 6,012 Location Kent Yes. Swapping it to users files in the normal start menu then swapping back doesn't change it either.
6 Mar 2007 at 15:33 #9 Gimpymoo Gimpymoo Soldato OP Joined 31 May 2005 Posts 15,654 Location Nottingham Thanks. At least I know its not my system playing up. Email to Mr gates it is then
6 Mar 2007 at 15:37 #10 WotDa WotDa Soldato Joined 6 Jun 2006 Posts 6,012 Location Kent [email protected]
