- 15 Feb 2011
- Slough
a friend of mine is looking for a prebuilt PC with a maximum budget of £1300-£1500
he said he really liked the ultima dreadnought, which is £240 cheaper than it would be up till tomorrow night, but he wont buy it because the lights on the fans are green, not purple
will it be easy to change the lights on the fans of said PC to one of the following:
- purple only
- blue only
- one purple, one blue
- colour changing lights
im also suggesting he goes for the SLI'd Asus GeForce GTX 480, is this wise, or should he save the £183 for a rainy day.
(personally i think he's being a bit dim rejecting this comp because of the lighting, because i cant find anything better for gaming for less that's prebuilt)
- purple only
- blue only
