- 29 Jun 2019
I'm trying to set up my fan curves properly in the bios rather than using MSI Control Center every time I boot, however when I go into the Hardware Monitor section of the (lite) bios and enable smart fan control I am unable to change the the values for temperature and fan speed from their default values. Does anyone know why this might be? It's the same for all four system fan headers and the CPU fan. I can highlight the line with the value in it but when I hit enter nothing happens, where a dialog box should pop up for me to enter the new value.
It's not really too much of a problem because I can save my fan curve profile in Command Center and activate it every time I turn my PC on but it just seems a bit of a faff when I should be able to alter this at the Bios level.
Many thanks.
Many thanks.
