- 8 Jan 2020
I have a 360mm front mounted radiator with 3x120mm fans on the back in a pull configuration, therefore pulling air from outside the case through the radiator and into the case. Infront of the radiator I have 2x200mm fans pushing external air through the radiator, so a push-pull configuration albeit with different sized fans.
The 2x200mm argb fans are not speed controllable, therefore run flat out and they are audible at 28dBA according to the specs. So, I am wanting to replace the 2x200mm fans with 3x120mm that can hopefully be run slow and still achieve the airflow keeping in mind that the 200mm fans are wider than the radiator so not all of the airflow they produce is going through the radiator.
I also have 3x120mm argb fans in the top of the case fitted to another radiator, that are very quiet when running at 40% power and I was thinking of getting another 3 of these 120mm fans to replace the 2x200mm fans on the front radiator.
Now for the airflow maths and noise calculations.
A single Cooler Master MF200R (200mm) fan running at 800 RPM produces 90 CFM of air flow at 0.88 mmH20 pressure with 28dBA noise output. Therefore two of those in parallel produces 180 CFM at 0.88 mmH20 and a noise output of 28(?) dBA.
A single Cooler Master SF120R fan running at 2000 RPM produces 60 CFM of air flow at 2.1 mmH20 pressure with 30dBA noise output. Therefore three of those in parallel produces 180 CFM at 2.1 mmH20 and a noise output of 30(?) dBA.
The 3x120mm fans would have to run at 2000rpm to achieve the same 180 CFM airflow as the 2x200mm and that the noise output of the 3 fans in total would still be 30dBA (the level of one fan or would it be higher).
But, if only 60% of the area of the 2x200mm fans actually covers the radiator then does that mean the 2x200mm fans are only pushing 108 CFM (60% of 180 CFM) through the radiator and therefore the 3x120mm fans (covering all of the radiator) only need to run at 60% speed to produce the same airflow? Does pressure effect these calculations? And how is the noise level effected? When running a push-pull configuration should each individual fan have the same CFM and pressure specs? What happens if if you are trying to push through more air than the pull fans are trying to draw through?
I hope someone can explain. Thanks.
