Hi all,
Last Autumn I replaced the front calipers on my Mrs. Fiesta Mk5 (1.25).
At the same time I replaced the front flexi hoses.
A few months prior to this I had fitted new pads and discs up front and new shoes and brake cylinders to the rear.
When I bought the callipers I did actually purchase a full set of hoses but haven't fitted the rears yet. If I recall I attached the new hoses to the new callipers before fitting anything then I could just spin the caliper if needed when attaching the other end of the hose to the fixed brake line.
Obviously I cannot spin the rears very easily. What is the normal procedure for replacing the rear hoses? I assume each end of the hose can spin independently otherwise the hose will twist? (OK, I should have dug them out of the shed and looked before posting) Also, will I need to bleed all 4 corners of the car after replacing just the rear hoses? Are there any tricks to ensure air doesn't go back in (perhaps by making a steady flow of fluid come out?).
Cheers.
Cheers.
