Changing Fluid and tubing
26 Nov 2012
Harrogate,North Yorkshire
Hey guys,
So, my water cooling setup uses 3/8 tubing and I am switching onto 1/2. I am also changing the CPU block as i'm also changing sockets and I like the idea of having a clean block.
As for the radiator/pump/res is there a good method for cleaning out the system? The pre-mixed liquid at the moment is Mayhems Black Oil stuff and I am switching to White fluid. Would I simply run the loop outside my case while pumping de-ionized water around until everything is clear? I just don't want to have to order 2 bottles of fluid and have one completely wasted during 'cleaning'.
going from black to white i'd say you're going to be cleaning for a long time!
you'll need to flush the rads with tap water a few times first and then flush with di water.
flush the pump /res with di water
clean any gpu blocks fully
make up a makeshift loop and run diwater for a few hours
empty it and run di water again (this helps cleat any droplets from the pump etc)
run until water is clear
profit
profit
I might just order the white tubing, out of sight out of mind right?
Good maintenance via flushing will also prolong the life of your components, I strip and flush my sys every 6 months and change all coolant and I have never had any probs.
Out of sight out of mind for gunky bits of old coolant :-)
Choice is yours.
gr8 kits
I cool my whole system with this. Rad mounted externaly 3x7v on fans.
While gaming cpu hits 67c max gpu 50c......
What more do you need ??
