22 Dec 2011 at 15:03 #1 DanMc07 DanMc07 Soldato Joined 6 Oct 2005 Posts 4,045 Here is what my sidebar looks like: How do I change the default directory path of my Picture folder so that it's the path of the Picture folder in my "Devices" Partition? Last edited: 22 Dec 2011
22 Dec 2011 at 15:16 #2 slinxy slinxy Soldato Joined 3 Dec 2002 Posts 4,130 Location Groovin' @ the disco you can drag the folder you want to the side bar... and use cmd+ drag to remove it
22 Dec 2011 at 15:17 #3 Feek Feek Commissario Joined 16 Oct 2002 Posts 344,704 Location In the radio shack Finder preferences, just drag that folder out and drag the correct folder in to the favourites section on the sidebar tab.
22 Dec 2011 at 15:22 #4 DanMc07 DanMc07 Soldato OP Joined 6 Oct 2005 Posts 4,045 That was easy! Thanks for the speedy replies
