- 19 Dec 2003
- UK
Hey folks, I currently have a Hive thermostat it's the current model as was fitted just under 2 years ago.
I do not have any wiring for the thermostat control itself, as the house never had a wired thermostat to start with, so no need to worry about that side of the wiring, all I need to do is swap the control module which plugs into the bottom of the boiler, from the Hive one, to the Nest one, is this something that will be relatively straightforward? (I would assume taking a photo of existing wiring etc beforehand).
Mine is a Worcester-Bosch Combi boiler so I am only using the thermostat for heating not hot water.
Has anyone done this swap themselves?
