Changing from nvidia to ati
A2Z
A2Z
Permabanned
9 May 2005
Earth
got my x1800xt, gona change to it from 6600gt
in what order do i uninstall current drivers/run drive cleaner/remove 6600gt/put in x1800xt/install new drivers (and which are best?)??
thanks
thanks
Uninstall Nvidia drivers in windows via add/remove software in CP, turn off.
Take out 6600GT, put x1800xt in.
Boot in safe mode.
Run driver cleaner.
Restart.
Install drivers.
Restart.
Drivers wise I'm using the Omega 6.3s with ATI Tray Tools with my X1800XT because I greatly dislike CCC. ATI have the 6.4s out on their site which are fine if you don't mind CCC, and the 6.5 betas are available, but they're not quite upto scratch yet.
fornowagain said:
Catalyst Control Center
any benefits of having this? i just want the driver, and the ati tools thing i think? to overclock the card..
Will ATI Tray Tools overclock the card when using 6.3 cats?
BTW the x1800xt is a fine card but compatibility/overclocking/fan noise etc is hell :D
Not sure if ATI Tray Tools can overclock these yet, I'm using the ATI Tool Beta :)
My X1800XT is nice and silently watercooled :D
Vegeta said:
Which beta are you using? I assume you dont use it to check for artifacts.
0.25 Beta 14
I don't get artifacts in ATI Tool like others, so I'll try the artifact checker out :)
Edit: My artifact checker works fine :confused:
