Hi,
Anyone heard of being able to tune the engine's setup so that the idle rpm will not fluctuate in relation to whether the cooling fan is running? The reason I would like to do that is that my idle rpm's drop by as much as 200-300 rpm when the cooling fan goes off and that makes hill-starts more tricky. Basically, I'm on a hill, raise the clutch to just the right spot, then right before I manage to press the gas peddle the idle RPM happens to drop off just then stalling the engine (people behind honking, etc).
It's a new Mazda 6 2.0 liter and I've been wondering why I've had occasional difficulties with hill starts in my new car (never had that problem on manual before)... THEN I noticed the RPM fluctuation... did some experimenting and determined for sure that it's the sudden inopportune drops in 300 rpm's that causes the stalls.
So can the Mazda mechanics simply "setup" the engine to STAY at the higher rpm level @Idle regardless of the cooling fan running or not??
Thanks, it would be nice to know a little more myself before I go to the service place.
Cheers
Cheers
